Bridge Plate Thickness?? http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=26302 |
Author: | crow-duck [ Sun Feb 28, 2010 7:48 pm ] |
Post subject: | Bridge Plate Thickness?? |
How thick should I make a bridge plate/patch? |
Author: | Mark Groza [ Sun Feb 28, 2010 7:55 pm ] |
Post subject: | Re: Bridge Plate Thickness?? |
I like mine between .090" to .099" depending on the top i use. |
Author: | Robbie O'Brien [ Sun Feb 28, 2010 8:24 pm ] |
.095 - 1.05 is a good window for a steel string bridge patch |
Author: | Mike Lindstrom [ Mon Mar 01, 2010 1:15 am ] |
Robbie O'Brien wrote: .095 - 1.05 is a good window for a steel string bridge patch Wow, that's a pretty big swing. Is that for heavy strings? ![]() Mike |
Author: | Christoph [ Mon Mar 01, 2010 1:26 am ] |
3mm for me |
Author: | Colin North [ Mon Mar 01, 2010 8:49 am ] |
It might help with replies if you ask for model you are building and bridge plate material to be used. Perhaps if you are more specific? I have use 2.5mm EIR, 3mm Maple (OMs), some people use different Rosewoods, BRW, Cocobolo etc. Also some people laminate bridge plates, with or without spruce in the laminate, etc. |
Author: | Robbie O'Brien [ Mon Mar 01, 2010 9:56 am ] |
Robbie O'Brien wrote: .095 - 1.05 is a good window for a steel string bridge patch Wow, what a difference a decimal point can make. I meant to say .105 |
Author: | Michael Dale Payne [ Mon Mar 01, 2010 5:00 pm ] |
Robbie O'Brien wrote: Robbie O'Brien wrote: .095 - 1.05 is a good window for a steel string bridge patch Wow, what a difference a decimal point can make. I meant to say .105 ![]() |
Author: | muthrs [ Tue Mar 02, 2010 9:10 pm ] |
The question is not how thick, but how stiff. Unfortunately I can't tell you how stiff, because I do it by feel. |
